Roof 16 head and domed pistons
Alex Dragone
First Name: Alex
Last Name: Dragone
* REQUIRED* Type and Year of Model Ts owned: 1910 Roadster, 1911 Torpedo, 1915 Touring, 1926 Roadster
Post by Alex Dragone » Mon Apr 22, 2019 3:50 pm
I am currently building an engine and have a Roof 16 valve head model BB and I am wondering if I can use the high compression domed pistons sold by parts vendors. I will be using a scat crankshaft as well. Any thoughts are appreciated. Thanks
Re: Roof 16 head and domed pistons
Post by Scott_Conger » Mon Apr 22, 2019 7:16 pm
What is the thinking of adding high compression pistons to an engine fitted with a high compression head? I'm not overly familiar with ROOF setups but believe that most certainly they were higher compression to work with the overhead valves...
tman1913
Last Name: Bender
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian touring, 1924 Roadster, 1926 Mercury speedster, 1927 Roadster p/u, 1920’s bobtail dirt track racer
Post by tman1913 » Mon Apr 22, 2019 7:52 pm
High compression piston will help in boosting the compression ratio. Standard T Model pistons would be lucky to give you any boost in C/R.
Scott the combustion chamber in Roof's overheads usually have more CC's than a stock Ford head.
Measure the volume of the combustion chambers in C/C's and let us know what piston you are planning to use. You stated that you are going to use a Scat crank, which one, Standard T or a Stroker.
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Mon Apr 22, 2019 10:23 pm
The overheads made in the T days were very low compression, not much more than a stock T, because the gas available then did not work well with high compression. The idea was flow with these heads. With modern fuel, you can use high domed pistons to improve performance.
Post by Scott_Conger » Mon Apr 22, 2019 10:28 pm
Mike/Eric
thank you for the lesson!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue Apr 23, 2019 1:27 am
I think the real question here is... how tall above the deck do the H/C pistons stick up above the deck? Most overheads have C/C depths between .875” and 1.125” depending on make and model.
Ross pistons has a O/H piston on file, you spec the height to get the C/R you want
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Tue Apr 23, 2019 1:59 am
Ross makes beautiful pistons, the nicest I have seen. They made the custom set we use in the Wild Cherry. They can make whatever you want if you need something special but have programs to make anything they have already done.
got10carz
Last Name: Meixner
Post by got10carz » Tue Apr 23, 2019 8:56 am
I have running BB.The stock Laurel pistons are flat top and come out of block 15/32".
got10carz
Last Name: Meixner
Post by got10carz » Tue Apr 23, 2019 9:00 am
Also I modified Ford Escort exhaust valves if you need valves.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 23, 2019 10:44 am
I found a Mercedes Benz valve that fit about perfectly!!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 23, 2019 4:26 pm
I used these valves
