Removal of 1926 fuel cover on cowling
dacapt1948
First Name: Phil
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1926 tudor
Post by dacapt1948 » Wed Oct 12, 2022 11:37 am
How do you remove the cowling fuel cap hinged cover? 1926.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Removal of 1926 fuel cover on cowling
Post by Humblej » Wed Oct 12, 2022 1:14 pm
Two screws on the hinge go thru the cowl and are held by two nuts. All are accessible with the gas door open.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Oct 12, 2022 1:19 pm
Accessible and removable are mutually exclusive, in my opinion. I could not get enough of a grip on screw heads to loosen them. Maybe soaking in Kroil will help.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Wed Oct 12, 2022 2:12 pm
Try 50/50 Acetone and ATF mix. Works better than commercial penetrating oils.
1926 Tudor
dacapt1948
First Name: Phil
Last Name: Terry
Post by dacapt1948 » Wed Oct 12, 2022 7:47 pm
Thank you all
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Thu Oct 13, 2022 9:26 am
Never turn a screw or bolt if it has a nut. Always hold the head hard with a well fitting driver and turn the nut. If it is a screw only, tap it as you turn in to assist breaking it loose, then tap as you loosen it.
Work honestly
Stay true to your word
Get the job done right
Petrah Phyre
First Name: Sean
Last Name: Pownall
* REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Post by Petrah Phyre » Fri Oct 14, 2022 11:17 am
Using this formula, do you mix it up as you need? My thoughts are that the acetone would flash off if not kept in an air tight container.
jab35
Last Name: Bartsch
Post by jab35 » Sat Oct 15, 2022 11:05 pm
Sean: I've got some in a pump type oil can and after 5 years it smells good and works well. You do need a closed container/oil can to reduce acetone evaporation, but the pump can does this. jb
Petrah Phyre
First Name: Sean
Last Name: Pownall
Post by Petrah Phyre » Sun Oct 16, 2022 9:05 am
Thanks James. I do have couple gallons of Kroll, but, as you are well aware, a couple gallons won't last forever when working on old stuff.
