worm
Melba Nolan
First Name: Melba
Last Name: Nolan
* REQUIRED* Type and Year of Model Ts owned: 23 roadster
worm
Post by Melba Nolan » Thu Oct 20, 2022 10:28 am
Does anyone know what this is
Re: worm
Post by Scott_Conger » Thu Oct 20, 2022 10:32 am
7:1 stock TT worm for rear end
KeithG
First Name: Keith
Last Name: Gumbinger
Re: worm
Post by KeithG » Thu Oct 20, 2022 10:48 am
Scott is on the ball!!! (We knew that anyway though). It only took him 4 minutes to answer Melba's question!!! :D
Adam
First Name: Adam
Last Name: Doleshal
Re: worm
Post by Adam » Thu Oct 20, 2022 10:49 am
AND, if they are rusty they generally aren’t usable. Even if properly cleaned it will likely be rough enough that it will rapidly wear the ring gear. Scrap steel is around $180 per ton, so 9 cents per pound might be a pretty fair price…
Re: worm
Post by John kuehn » Thu Oct 20, 2022 2:11 pm
It depends if it’s rusted enough to be pitted. If it’s not pitted it will clean up and will be serviceable.
Re: worm
Post by Mark Gregush » Fri Oct 21, 2022 1:06 pm
It has been re-machined to fit a T U-joint and might have been used in the homemade tractor or power drive using a TT rearend. The end that is now square would have been splined to fit the coupling where it would have been attached to the driveshaft. Even if it could be cleaned up, looks like it would, it would have minimal value and only to someone building such a piece.
