A Brass Clear Coat Discolor Problem
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Oct 23, 2022 9:33 am
When shiny brass is clear coated to keep the shine and turns brown in 15 years, what is the best way to remove the old clear coat?
Should the coating just be left off after polishing the light in the beginning?
Re: A Brass Clear Coat Discolor Problem
Post by TXGOAT2 » Sun Oct 23, 2022 9:38 am
"Will not chip, crack, peel, yellow, or fade"..... except IT ALWAYS DOES. Don't clear coat brass with anything you can't wipe off easily.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Sun Oct 23, 2022 10:12 am
Since it's already been coated these fifteen years a-gone, the question is, how to remove it ? Lacquer thinner would be a good solvent to try at first. It could be pretty stubborn.
I agree with Pat, it's usually best not to coat polished brass with anything, but then, there's the polishing. Fun for some, not for all. :lol:
Get a horse !
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sun Oct 23, 2022 11:33 am
I recently went through same problem. I had to use brush on aircraft paint remover, it took multiple applications to remove it all. Lacquer thinner won’t touch stuff that’s been on there for decades.
Last Name: Wrenn
Post by TWrenn » Sun Oct 23, 2022 6:14 pm
If lacquer thinner won't take "something" off, it's probly due to the chemical makeup of the product, not how long its been there.
Like Rich says...I don't coat anything. But then, being a shiny brass snob, I do like to polish brass. I know I'm sick-minded! :lol: But it does give me therapy and a sense of accomplishment when I'm done and it's so shiny!
Sean Butler
First Name: Sean
Last Name: Butler
Post by Sean Butler » Wed Nov 02, 2022 4:55 pm
I used DMF or Dimethylformamide on some very nice repop lights I had purchased. Very nasty stuff but worked great. Not sure where you can get it but I was lucky to work in a plastics plant with all sorts of nasty chemicals. I am in agreement with the other posters, Don't coat your brass!
Sean Butler
Huntington Beach, CA
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Nov 03, 2022 8:19 am
This was a successful removal without harsh chemicals.
viewtopic.php?t=22606
Loftfield
First Name: Thomas
Last Name: Loftfield
Post by Loftfield » Thu Nov 03, 2022 8:30 am
While you are trying various solvents, there is always acetone and methyl ethyl ketone (MEK) the latter being PVC pipe cleaner. Both are a little more aggressive than lacquer thinner. Even lacquer thinners come in varying degrees of aggressiveness depending on the temperature of the lacquer for which they are designed.
