Need advice on a tool
AdminJeff
Post by AdminJeff » Thu Oct 27, 2022 1:51 pm
I'm trying to remove stuck bearings from Ford Model T starter and generator end housings. It wouldn't be a big deal, but I now have about 10 of these. I've tried heating them but no luck. There's only about 1/8-3/16" of clearance behind the bearing.
Anyone know of a tool that will remove these short of drilling holes in the back of the housing?
Jeff
Last Name: Hatch
Re: Need advice on a tool
Post by Dan Hatch » Thu Oct 27, 2022 1:56 pm
Blind bearings puller. Do it all the time.
AdminJeff
Post by AdminJeff » Thu Oct 27, 2022 2:02 pm
Perfect thx. Looking on Amazon now!
Last Name: Strange
Post by CudaMan » Thu Oct 27, 2022 4:39 pm
Probably won't work on the ball bearing, but for the sealed one you could try packing the cavity behind the bearing with grease, then carve a wood dowel to the size for a sliding, but not too loose fit in the bearing bore. Drive the dowel into the center of the bearing and the hydraulic pressure from the grease will force the bearing out. Folks use this method to remove flywheel pilot bearings. I've seen them use hand soap, or even bread! :)
AdminJeff
Post by AdminJeff » Thu Oct 27, 2022 9:30 pm
Brilliant! I ordered a set of blind bearing tools today. I'll try this on the sealed ones - there are 4 of them.
jiminbartow
Last Name: Patrick
Post by jiminbartow » Thu Oct 27, 2022 10:21 pm
This is called a slide hammer bearing puller. My Dad had one and it worked great. There are the more expensive ones that have numerous ends to fit various sized bearings. For the generator bearing, the spring loaded arms with the outward pointing hooks are squeezed together and inserted into the hole and released. The arms will open outward catching the inside edge of the hole and the bearing is pulled out by forcefully pulling the slide hammer upward and banging against the underside of the handle at the end of the shaft. Jim Patrick
AdminJeff
Post by AdminJeff » Fri Oct 28, 2022 12:28 am
I Have one on order! I'll let you know how it works.
Jeff
jiminbartow
Last Name: Patrick
Post by jiminbartow » Fri Oct 28, 2022 12:52 am
Maybe a little Kroil around the outside of the bearing would aid in easing the bearing out when using the puller. Jim Patrick
Scott C.
Last Name: Clements
Post by Scott C. » Fri Oct 28, 2022 1:55 am
As Dan suggested, a blind hole puller will work. So would a pilot bearing puller. As for the grease and a rod to drive in, that works too. I saw a video where the guy used a piece of bread and stuffed it into the cavity and used a hammer and rod. It worked great to, and no greasy mess to clean up.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Fri Oct 28, 2022 10:23 am
But you have to have enough "dough" ! :lol:
Get a horse !
AdminJeff
Post by AdminJeff » Fri Oct 28, 2022 11:31 am
Actually cooked dough… I got lost watching videos on YouTube last night and there are dozens showing how to remove a blind bearing with bread. Fascinating.
