WTB: Top Saddles
Scott C.
Topic author - Posts: 863
- Last Name: Clements
WTB: Top Saddles
I am looking for a set of Ford marked top saddles. Does anyone have some that they would sell?
Re: WTB: Top Saddles
For what year Scott ? 1/2" or 5/8" hole ?
RichJ
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
Scott
I have a nice pair , with good used straps. they have a 1/2"hole $40.00
RonGlowczewski
GIVE SCOTT CLEMENTS FIRST DIBS, but I am also looking to buy a pair of 1/2" top saddles with the arms and straps. Only interested in originals.
All I have left are for 5/8" irons.
havnfun
- First Name: Joe
- Last Name: Kowalczyk
Easy to turn 5/8 into 1/2 using an old brass spindle bushing and trim off excess. They slide right in easily, mark for hole, remove and drill slightly larger hole, once fitted, paint. To turn back into 5/8 easily remove bushing.
- Attachments
- D876EEA8-B85C-4E59-8AD6-AF450E095422.jpeg (32.26 KiB) Viewed 3620 times
Regards,
Well, that's a handy fix Joe !
Scott C.
Rich, I sent you an email.
Scott C.
Still looking.
Scott C.
Still looking for a set saddles.
The Ford script saddles were only made with the small hole to my knowledge. There are those with as series of dots cast into them. I've never figured out what those dots mean, but there had to be some reason for it. You can't even see those dots when the leather pad is in place, but I had a good friend come over one day and wanted to know if I had an extra with the same number of dots his had, so I was able to help. I believe all the early top saddles used from 13 on up to ? had a rounded bottom. Both of my 1913's have those.
Scott C.
Still looking for a set of saddles.
RichJ
- First Name: Rich
Scott
Here is another set I recently acquired . appear to be original but no markings,1/2 inch holes
RichJ
- First Name: Rich
E Mail sent
Don ellis
- First Name: Don
- Last Name: Ellis
- * REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
These are on my 23 I’m working on. One has a circle with an M in the middle and one dot. The other just has two dots.
