Centerdoor dash question
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Fri Oct 28, 2022 3:15 pm
I brought home a 19 centerdoor earlier this year. Being a 19 it is a starter car. The metal instrument panel is attached to a wood panel behind it. There are holes in the wooden panel, for I assume a steering column bracket, but no holes in the metal panel. There are no signs that a steering column bracket was ever present. Does anyone know if these early starter cars had a steering column bracket? The panel is notched out for the column to rest in but, it does not appear the column was ever attached to the instrument panel. Very odd
Stephen
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: Centerdoor dash question
Post by mtntee20 » Fri Oct 28, 2022 5:05 pm
Stephen,
Our late '19 - early '20 Center door had/has a steering column brace/bracket. It does not have the original dash in it so I do not know the 100% correct answer to your question. I am planning on keeping the bracket as I think it will give good support to the steering column. I will have to do some research on the dash to ensure I have something close to original.
Good Luck,
Terry
Last Name: House
Post by George House » Fri Oct 28, 2022 6:39 pm
Here’s my ‘19 centerdoor dash. Hope this helps. I might have another metal dash hanging up. Email me if you need it. I’ll look tomorrow...forgive the dangling horn button. I lost the top-of-column sheet metal cover.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sat Oct 29, 2022 1:32 pm
My 22 was missing that piece, so I made one as I could see the paint outline of the original
William L Vanderburg
1922 Center Door Sedan
Stephen_heatherly
First Name: Stephen
Post by Stephen_heatherly » Mon Oct 31, 2022 12:13 am
Thank you for your replies. Looks like I need to find the bracket for my car.
Stephen
