Cumbustion volume of head gasket
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Sat Oct 29, 2022 9:14 pm
I measured the combustion volume of the head gasket. It is about 1.11 cu in. Is this taken into consideration whrn determining combustion ratio. The compressed gasket thickness measured .060 in
Art Mirtes
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Cumbustion volume of head gasket
Post by Dan McEachern » Sun Oct 30, 2022 2:43 pm
Art- I agree, you number is pretty close to what I use.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Sun Oct 30, 2022 3:28 pm
Dan.
I am wondering how or where you otained your number I used an ancient drafting instrument called a polar compensating planimeter. I don't know how accurate it is. But must be fairly accurate since our numbers are close
Thanks for responding
Art Mirtes
Harry Lillo
First Name: Harry
Last Name: Lillo
* REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
Post by Harry Lillo » Sun Oct 30, 2022 4:49 pm
Perhaps I looked at this too simplistically.
Is it not the volume of a cylinder
Diameter 3.75 in
Height 0.060
3.14 X (3.75 / 2) squared x 0.060
I get about 0.66 cubic inches
Harry
Dan McEachern
First Name: DAN
Post by Dan McEachern » Sun Oct 30, 2022 5:59 pm
Harry-its the volume of a head gasket, which is not a cylinder, as you have to include the valve area as well. Art- its been several years, but I recall that my volume was an actual measured volume using a flat plate and a pipette.
