1926/27 Rear Axle in 1925 Touring
Tom Dove Jr
Last Name: Dove
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring, 1925 parts car(?)
Board Member Since: 2022
Post by Tom Dove Jr » Thu Nov 03, 2022 2:49 pm
All things being equal, would it be an upgrade to install the later rear axle assembly in a 1925 T??
Will internals interchange if needed?
Ultimately will be installing the Rocky Mountain brakes.
Thanks!
Tom
I have never let my schooling interfere with my education.
Education consists mainly of what we have unlearned.
Re: 1926/27 Rear Axle in 1925 Touring
Post by Jerry VanOoteghem » Thu Nov 03, 2022 2:55 pm
Thanks!
Tom
That's what I have in my '25 Touring. Works fine. Yes, internals are the same. The "upgrade" is in having larger parking brake drums.
Post by speedytinc » Thu Nov 03, 2022 2:56 pm
ABSOLUTELY. I run one in a 23 touring, over 40 years now. I do not run RM brakes (actually removed them).
The big drum brakes are equivalent when maintained.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Thu Nov 03, 2022 3:01 pm
Tom.. if your engine number is into the vicinity of September of 1925, I would bet it would be acceptable to have the improved rear axle installed, since in all Ford upgrades there is no definitive day that all factories started using the changes.. they would have to use up the stock parts that they had before the change before the improved replacements...... Not related to your question but I could tell you that the 1922 touring at the Thomas Edison estate in West Orange New Jersey not only has the improved axle but it also has the four to one "mountain axle gearing" but also has other improvements installed that were tested before they made the assembly line.
Tom Dove Jr
Last Name: Dove
Post by Tom Dove Jr » Thu Nov 03, 2022 3:42 pm
Jerry, Speedy, and Moxie, thank you!!
T
Tom Dove Jr
Last Name: Dove
Post by Tom Dove Jr » Thu Nov 03, 2022 3:49 pm
Seems to me I recall hearing something along those lines. As I am always on the front end of maintenance, those $$$$ can certainly be used elsewhere.
T
Last Name: Hjortnaes
Post by DHort » Thu Nov 03, 2022 4:41 pm
You will also need new radius rods. They are shorter in the 26-27 axle.
Tom Dove Jr
Last Name: Dove
Post by Tom Dove Jr » Thu Nov 03, 2022 8:13 pm
Fortunately those are part of the package. 👍🏻
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Fri Nov 04, 2022 8:39 am
You may want to use your earlier spring perches unless you want to lower the rear of the car about an inch.
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Fri Nov 04, 2022 8:55 am
I have a large drum ruxtell in my ‘14. Main reason is I had one. Benefits, larger brake and I like the look of the drum more so than the flat Rocky Mountain add on drum. Did not change the height of the car.
Andy
