Painting embossed badges, keys
RGould1910
Topic author - Posts: 1240
- Last Name: Gould
I received a request to upload photos of embossed pieces I painted by using 400 grit sandpaper wrapped around a nail to reveal the high spots.
Re: Painting embossed badges, keys
What about the hubcaps Richard? I know they did them in 1913-15. I'm not sure about 1912.
Fire_chief
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
I tape off the outer edges of the hubcaps, then paint the entire top. I then let it cure for a week. I then wet sand them till the raised parts are completely showing. Followed by polishing the brass.
jiminbartow
- Last Name: Patrick
When the raised letter edges are rounded off, how do you keep from squaring off the edges after painting and are removing the cured paint from the raised letters?
I have done this with the patent plates of “Victor” and “Edison” phonographs when I was into restoring antique phonographs. Once the paint has been built up in the area between the letters to the top of the letters, I let it dry hard, then wet sand it on a piece of 1200 grit wet/dry sandpaper. You can then, polish the paint and the raised metal portion with a good rubbing compound. I use Meguiar’s rubbing compound which will polish both the paint and the brass metal to a mirror shine. If you want a good flat surface, cut an old soft T shirt and stretch it flat on a table and tape the corners of the T-shirt to the table top, squirt a little rubbing compound onto the cloth and rub the painted badge, key, or patent plate back and forth until the paint and metal is polished to a high shine. If the background paint has been built up to the top of the letters, the paint and metal can be polished in the same application. Jim Patrick
