Question
Rick Nelson
First Name: Rick
Last Name: Nelson
* REQUIRED* Type and Year of Model Ts owned: 1914-1917-1926
Question
Post by Rick Nelson » Sat Nov 12, 2022 1:29 pm
Has anyone ever experienced this? I have reverse bur no
Forward high or low
Last Name: Seth
Re: Question
Post by perry kete » Sat Nov 12, 2022 1:33 pm
Could be stuck in neutral?
Re: Question
Post by TXGOAT2 » Sat Nov 12, 2022 1:34 pm
What happens when you push the clutch (left) pedal down hard? Do you have neutral with the parking brake lever halfway back?
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Question
Post by Rich P. Bingham » Sat Nov 12, 2022 1:44 pm
Nope. Never.
Let the guessing begin. If you have reverse but no low, the "easy" answer is that the low band is A: missing (?!?) B: totally worn out C: way out of adjustment.
The "hard" possibility, perhaps the drum rivets have sheared off the gear shaft (really rare).
No lockup in high -? Multiple possibilities, the simplest being the clutch linkage is out of adjustment. Disconnect the pedal from the throwout lever, make sure the hand lever cam is not interfering and you should be able to tell if the clutch has engaged.
If not, follow the manual directions for adjusting the clutch fingers and all pertinent linkage. Look first to be sure the clutch spring is not broken.
Good luck !!
Get a horse !
Rick Nelson
First Name: Rick
Last Name: Nelson
Re: Question
Post by Rick Nelson » Sat Nov 12, 2022 5:17 pm
I guess I should clarify, I am not new to model Ts but not claiming to be an expert. Just out for a drive one day every thing working great, stopped at a stop sign and that was it no strange sounds, nothing, just wouldn't go forward. I restored it in 2009 and replaced anything that was bad (or so I thought) I was just hoping someone would have had similar problem. I guess I will have to do what I figured all along and pull the engine.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Re: Question
Post by Rich P. Bingham » Sat Nov 12, 2022 5:24 pm
It may well come to that. Interesting case, I hope you will keep us informed of what you find out as you progress to find the cause.
Get a horse !
Re: Question
Post by John kuehn » Sat Nov 12, 2022 5:35 pm
Have you opened up the transmission cover? Look inside and depress the pedals and see what’s happening. You may have already done that.
Check the linkage inside and out. Check the pedal shaft pins. Maybe a pin sheared.
With the engine off put the handbrake in neutral. Then try to turn the crank. You should be able to do that with not much resistance. Then put the handbrake all the way forward and you should be able to move the car forward a bit or at least some. Those are simple checks to start with as you might know already.
Other internal things might be the clutch drum set screw may have gotten loose, or something similar.
Hope it’s something external and not something that’s gotten loose inside the transmission.
dykker5502
First Name: Michael
Last Name: Deichmann
Re: Question
Post by dykker5502 » Sun Nov 13, 2022 6:14 am
Not exactly the same pattern, but I have experience a locked transmission with only high, no clutch and no low (did not try reverse) and that turned out the be a broken tooth that have blocked the triplegear. It was a rebuild of the gearbox :-/
Ford Model T 1914 Touring
Rick Nelson
First Name: Rick
Last Name: Nelson
Re: Question
Post by Rick Nelson » Sun Nov 13, 2022 5:57 pm
Thanks for everyone's input. I am probably not going to
Mes with it until spring. It is tucked away and the snow is falling. And I am working on a 17 couplet for the winter
