Valve Seals advice
Topic author - Posts: 6707
Re: Valve Seals advice
....No....
Erik Barrett
- First Name: Erik
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1924 touring 1925 dump truck
Valve seals no. Valve seats sometimes.
- First Name: craig
- Last Name: leach
Webster may be referring to the Secrets of Speed using felt washers to stop air & oil leaks in engines run at sustained high speeds.
I would suspect seals in a normally run engine would rob the valves of any lubrication they get in a flat head engine.
