Silicon Bronze Main Caps and Babbitt
got10carz
Last Name: Meixner
Post by got10carz » Sun Nov 13, 2022 8:06 pm
I have silicon bronze caps to install A crank in T block. Can't seem to be able to flux the caps to accept babbit. Tried different temperatures and flux. Any ideas.
Re: Silicon Bronze Main Caps and Babbitt
Post by Scott_Conger » Sun Nov 13, 2022 8:27 pm
what are you using for flux and tinning?
what exactly is happening?
got10carz
Last Name: Meixner
Post by got10carz » Sun Nov 13, 2022 8:36 pm
1 flux was Eastwood. Using the babbit to tin. I'm not getting the shiney finish that a tinned steel cap gives you.
Babbit is not sticking to surface
Post by Scott_Conger » Sun Nov 13, 2022 9:04 pm
I'll assume you're getting things as clean as possible, but perhaps are burning the flux?
Might try these guys for flux made especially for babbit: https://superiorflux.com/products/indus ... bitt-flux/
