High Compression Heads and Bore Size
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Thu Nov 17, 2022 12:07 am
Can you use a high compression head if your bore size and pistons are not stock? For example, my pistons are .030, would a Z head have issues?
Last Name: van Ekeren
Re: High Compression Heads and Bore Size
Post by Kerry » Thu Nov 17, 2022 12:12 am
No issues with bore size, just piston height needs to be checked.
Post by Allan » Thu Nov 17, 2022 12:24 am
There are inconsistencies with some Z heads. They need to be carefully matched to the cylinder block. Oversize pistons are not the worry. You just might have to do a little re-shaping of the combustion chamber at the interface with the gasket.
The Prus heads are a better choice in my opinion.
Tim D
Last Name: Dickson
* REQUIRED* Type and Year of Model Ts owned: 1912 speedster 1911 Torepdo
Post by Tim D » Thu Nov 17, 2022 11:15 am
I have been running a Z head for 20 years and my block is bored .080" over. with alum pistons. No problems.
Tmooreheadf
Last Name: Moorehead
Post by Tmooreheadf » Thu Nov 17, 2022 9:23 pm
The last Z head I used required some relief grinding on the interior edged on all 4 chambers to prevent piston interference on a .030 oversized bore. I tried a Prus head on another engine bored .030 over with no modification needed. Prus advertises .080 with no interference and that seems to be correct.
JBog
First Name: Jason
Last Name: Bogstie
Post by JBog » Thu Nov 17, 2022 10:12 pm
Thanks, guys!
