Transmission Brake Band Spring Tool
Bill Everett
Topic author - Posts: 322
- First Name: Bill
- Last Name: Everett
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1914 Touring, 1912 Roadster PickUp in process
- Board Member Since: 2011
How does this tool mount so that I can take off the brake pedal without tension from the spring pushing the nut and/or washer out, and into the transmission?
Any help would be appreciated.
Thank you.
RGould1910
- Last Name: Gould
Re: Transmission Brake Band Spring Tool
I bring the ears together so I can unscrew the nut and remove the nut and washer from the pedal shaft. I hold it at a 45 degree angle so each prong sits just under the rearward lip of the band. To be a safe I stuff the surrounding open areas with crumpled paper towels so things don't fall down in the pan.
Bill Everett
- First Name: Bill
Thank you, Richard.
When you stuff rags in the transmission to catch things that might be dropped, count them going in and coming out.
