1915 Bulb Horn Blockage?
Fozz71
Last Name: Chochole
Board Member Since: 2003
Post by Fozz71 » Sat Apr 27, 2019 3:44 pm
I am having an issue on my '15 bulb horn- when I squeeze the bulb normally I get backpressure and the bulb resists being squeezed which means very little (but good tone) sound. Its not all the time, but if I squeeze the whole thing= resistance, if I squeeze a portion of the bulb then it works.
Any idea what gives?
Jim
Re: 1915 Bulb Horn Blockage?
Post by Original Smith » Sun Apr 28, 2019 10:23 am
Probably the reed is stuck. Gently clean it, but don't mess with the flapper, or it may not work at all!
Fozz71
Last Name: Chochole
Post by Fozz71 » Sun Apr 28, 2019 10:51 am
What's the best way to clean a reed?
Last Name: Wrenn
Post by TWrenn » Mon Apr 29, 2019 8:35 am
Or maybe a spider got in there somewhere and plugged it up. Ya never know! ;)
Mountainrider
First Name: Neil
Last Name: Haywood
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Post by Mountainrider » Mon Apr 29, 2019 4:58 pm
Same problem,I moved my reed from just after the bulb down to just before the horn. Works great now
