Wire Wheel Lug Nuts
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Wire Wheel Lug Nuts
Post by BRENT in 10-uh-C » Sun Dec 11, 2022 3:41 pm
I am wanting to convert my '26 Depot Hack over to wire wheels. I have straightened & restored wheels, along with correct hubs ready to install however I do not have any lug nuts. Am I correct that reproduction original-style lug nuts are out of production? What are options??
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Wire Wheel Lug Nuts
Post by ModelTWoods » Sun Dec 11, 2022 3:55 pm
If the vendors are out, options are: 1. find someone with new reproduction nuts who will part with them, OR 2. find some original or reproduction nuts that need replating and have them replated, I do not know if Model A nuts will work. Maybe you know, Brent. I do think that A and T are the same thread, although the taper or the shoulder against the wheel may be different. Of course, if they do work, they won't be correct, but they'll hold a wheel on a hub, until you can find correct ones. These are modern application nuts but check and see if they will work until you can get the right ones: Ebay listing 383102515260.
Professor Fate
Last Name: S
Post by Professor Fate » Sun Dec 11, 2022 4:50 pm
I got a full set (20) from Lang's 7 months ago. Make sure you use the washer for each nut.
________________
**FATE**
Last Name: Hatch
Post by Dan Hatch » Sun Dec 11, 2022 5:44 pm
Brent : There is a trailer lug nut that looks a lot like T lug nuts.
Just be sure to get the solid ones.
Dan
Post by speedytinc » Sun Dec 11, 2022 6:14 pm
The modern version in the ebay listing.
Yes these are the one's I run on my 27. The short version. I believe the hex size in the originals is a bit smaller. 11/16. these are 3/4 "
They look very close to the original ones.
Post by Allan » Sun Dec 11, 2022 6:18 pm
When I built my speedster, I bought modern chrome plated nuts which were so close to originals you had to get down and read the numbers stamped in them to know they were not the real thing.
Post by speedytinc » Sun Dec 11, 2022 6:22 pm
Some do have #'s stamped on them, some do not.
I run the un marked nuts. Yes, you cant tell them from original @ 5 feet.
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
Post by BRENT in 10-uh-C » Wed Dec 14, 2022 9:28 am
Thanks guys, ...I'll just order some of the eBay ones and be done with it.
