Any advice on Removing a stubborn inner bearing seal.
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sun Dec 11, 2022 9:36 pm
I am doing a tuneup on my brakes and outer axle bearings and seals but one of my inner seals won’t budge. The other one came out with a pair of mechanic’s magnets (the ones on long rods). I tried using a long mechanic’s pick but there is nowhere to get the pick in and I don’t want to scratch the axle.
Any advice on how to get it out? I was thinking of drilling and tapping a couple of holes and pulling it out, but that would make a mess that would hard to clean up.
Re: Any advice on Removing a stubborn inner bearing seal.
Post by speedytinc » Sun Dec 11, 2022 9:45 pm
I have had success with a long general scribe. the 90 degree end can be worked in between the axle & seal washer.
Your idea of drilling 2 opposed holes & using long sheet metal screws was a similar method recommended for removing transmission seals on old harleys.
Cleaning the chips from a steel washer drilling is easy with a magnet.
Post by Steve Jelf » Sun Dec 11, 2022 9:51 pm
I use a piece of ³⁄₃₂" welding rod. Bend one end 90º for a handle 4 or 5 inches long. Bend a small hook at the other end. About ¼" is plenty long for the hook. Then grind the hook end flat enough to fit between the axle shaft and the seal. I keep this in my box of specialized rear axle tools.
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Dec 11, 2022 10:19 pm
Maybe take John & Steve's ideas X 2 180 degrees apart just to be safe?
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sun Dec 11, 2022 10:35 pm
Thanks. I dimpled it slightly with a punch in 4 places and it came out. The only thing I can think of is that it was stuck with dried grease.
