Roadster vs coupe?
Dennis Prince
Last Name: Prince
Roadster vs coupe?
Post by Dennis Prince » Wed Dec 28, 2022 10:56 pm
Can anyone tell me if I can use 26/27 coupe/sedan inner fender patch panels on a 26 roadster turtle deck? I don't need them to fit perfectly just along the bottom few inches. Thanks, Dennis
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Roadster vs coupe?
Post by Kevin Pharis » Wed Dec 28, 2022 11:11 pm
There’s nothin special about the bottom few inches of a 26/27 roadster wheel well. Can be easily made from a strip of sheet steel and some simple hand tools. Careful assembly is arguably more important than a good fitting panel. Here’s a pic of the repair work I did on my ol ‘27 roadster
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Dec 29, 2022 8:26 am
Although the 26-27 coupe and roadster use the same rear fenders, the trunk side construction and the inner fender Pannels are different.
