What have you done with your Model T in January
TFan
First Name: Jim
Last Name: Riedy
Post by TFan » Sun Jan 01, 2023 10:52 pm
I'll see if I can be first this year. My wife and I along with Champ took our annual New Years Day drive around our downtown which borders Sandusky Bay. It was a little chilly at 47 degrees but much better than last week. The first pic is in front of the salt dock along the bay (IN CASE YOU WONDER WHY OUR CARS RUST SO BAD this is the reason) pics 2&3 are at our shoreline park at the opposite end of our downtown. I was able to put about 5 miles already this year. Yippy! Jim PS. Happy New Year
Last Name: Wrenn
Re: What have you done with your Model T in January
Post by TWrenn » Mon Jan 02, 2023 11:57 am
Congrats Jim! Yep you're first in line, and heck it's already Monday even and no one's been doing anything to their T's yet I guess :lol:
I ALMOST took the Fordor out but played the lazy card instead. Glad you Bonnie & Champ got out!! Especially Champ. I'm sure he was going through withdrawal!
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Mon Jan 02, 2023 2:35 pm
I would have driven out T yesterday probably for an ice cream run but it rained hard all day.
Bummer! Maybe we'll go for a ride today.
got10carz
Last Name: Meixner
Post by got10carz » Mon Jan 02, 2023 2:46 pm
Setting valve clearance. Chev LS valves, A-B tappits, B cam with .320 lift
Post by speedytinc » Mon Jan 02, 2023 2:51 pm
A-B tappets? Ever do this before? How do those thin lifter castings hold up?
Any particular reason for not going to a stock T oversize?
Inquiring mind on the loose.
got10carz
Last Name: Meixner
Post by got10carz » Tue Jan 03, 2023 11:42 am
John, I've never done it, but it is well documented. I'm not worried about the casting being thin.
The reason to do it with the B cam is that the foot is much larger on the AB tappit. If you put a T tappit in the duration of the lift would be much less. Lift would stay the same.
The other thing I will add to all this is it's not a job for the weak of heart.
Post by speedytinc » Tue Jan 03, 2023 11:56 am
Good to know. Thanks for your reply.
Angmar
Last Name: Bailey
Post by Angmar » Thu Jan 05, 2023 2:49 pm
Got out in the snow for a bit....cold. Running on the pavement with chains is a bumpy proposition.
PXL_20221231_221516276 (2).jpg (51.09 KiB) Viewed 9635 times
Still crankin old iron
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Thu Jan 05, 2023 4:29 pm
What a great pickup Mark. I use about a 5/8 rope for mud or snow. Does not hold up well on road, but off road its great.
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Thu Jan 05, 2023 4:46 pm
Moved it out from the paint booth where it was when the tornado struck.
Vern (Vieux Carre)
TrentB
First Name: Trent
Last Name: Boggess
Post by TrentB » Sun Jan 08, 2023 5:53 pm
I decided I wanted to check the alignment of a Model T connecting rod using the KR Wilson alignment fixture:
The C clamp’s purpose is to hold the spider tight in the top of the rod. The spider is not machined to accept a piston pin clamping screw.
All of the old time rod alignment fixtures I have used suffer from the same drawback: you need different mandrels for undersize rods. I only have a standard size mandrel for the Wilson fixture. I made up .010, .020 and .030 undersized mandrels for my Stevens rod alignment fixture. I haven’t done so for the Wilson… yet.
Respectfully Submitted,
Trent Boggess
abcarswell
First Name: Bruce
Last Name: Carswell
* REQUIRED* Type and Year of Model Ts owned: 1924 Model TT, 1934 Fordor
Post by abcarswell » Fri Jan 13, 2023 1:08 pm
Finally had a chance to chase down an overcharging issue that showed up on my last drive back from a nearby car show in October. Blew out both headlight bulbs. Researching this forum pointed me to the generator-ammeter-battery circuit. Sure enough found a meltdown on one of the terminals of my repop ammeter. It wasnt grounded when I checked it but I suspect when the insulation inside and out was hot and gooey, it was grounding. Found another repop but also on the hunt for a decent original. I did modify the repop per the YouTube video about soldering the internal terminals to eliminate a potential source of heat from poor connections.
Post by speedytinc » Fri Jan 13, 2023 1:39 pm
Good looking used originals show up on ebay frequently for reasonable money. There were 3 more added this week.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sat Jan 14, 2023 4:05 pm
Pressed some new bushings in the spindles. Iam waiting for the proper mandrel to show up for the Sunnen hone then they will be sized for the king pins.
Pressed in the triple gear pins in the flywheel then test fit the gears with caged needle bearings
Had the trans drums checked for cracks. All is good so pressed in the new bushings. Next they will be sized to each other.
The drive plate passed the crack test but had some loose rivets so out they go and I will try my hand at installing new ones.
And still having fun with it!
Bryant
Post by Scott_Conger » Sat Jan 14, 2023 4:20 pm
Wish you had asked first on the drum bushings...it is exceedingly rare that they wear beyond serviceable limits, and if replaced, they should be reamed concentric to the pitch diameter of the gear which revolves around it...not an easy thing to accomplish without special tools or extensive set-ups.
Do a LOT of study on the forum for proper clearances particularly the brake drum to output shaft bearing clearance.
You did yourself a big favor by going with Dan's triple gears but took a step back by changing those big bushings.
Maybe give significant consideration to reaching out to someone set up to make all of those drums fit together correctly and contract with them to do the final fitting/reaming
As for installing rivets, take a look at YouTube to see how Mike Bender does it. You will learn exactly how to do it and have it very secure. I like his method and assure you it is not something that is particularly intuitive until you see it done.
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Sat Jan 14, 2023 4:36 pm
Thanks Scott! I have been collecting information about the drums for awhile. I will be visiting my friend with the machine shop to finalize the job. If he can’t do it nobody can. I did watch the model t tips video on the rivet job. It gave me the confidence to go for it.
Bryant
Wayne Mims
First Name: Ervin
Last Name: Mims
* REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
Post by Wayne Mims » Sun Jan 15, 2023 6:17 pm
New Year's Eve I went for a drive in my 13 and watch the fireworks.
Sorry I'm late but I'm not used to using this computer I am still learning how to fly this thing
Post by RajoRacer » Sun Jan 15, 2023 7:59 pm
Can't say I've ever seen a firewall extension on a '13 ?
Arbs
Last Name: A
Board Member Since: 2022
Post by Arbs » Sun Jan 15, 2023 8:15 pm
Scott C.
Last Name: Clements
Post by Scott C. » Mon Jan 16, 2023 1:34 am
I installed a freshly rebuilt generator from Jeff Stevenson on my 26 Roadster.
Lil Teezy
First Name: Chris
Last Name: Levi
* REQUIRED* Type and Year of Model Ts owned: 1926 touring 1927 roadster
Post by Lil Teezy » Mon Jan 16, 2023 5:15 pm
Reallly fresh whitewalls
Put on the knobby tires and took advantage of the garage time to get the car warm enough to start, haha! Then got very messy…
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Mon Jan 16, 2023 6:28 pm
I got my frame , front axle assembly and rear axle assembly painted on this warm day.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Wed Jan 18, 2023 10:21 pm
Swapped the vaporizer out in my 27 coupe for a Stromberg OF. Also replaced the failing exhaust pipe/muffler. Little steps.
Brad
Tbird
Last Name: Bird
Post by Tbird » Thu Jan 19, 2023 2:19 pm
Made some more saw dust…
John Illinois
Last Name: Burgett
Post by John Illinois » Sat Jan 21, 2023 3:21 pm
Installed anew radiator which I bought a couple of years ago. Getting closer to being done with the rebuild. Was lucky to have the Bergs radiator.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Jan 23, 2023 8:39 am
I found bits of broken brush holder insulation when I replaced a starter bushing. I replaced the insulators but still need to face the bushing for proper fit. It's too cold in the barn to spend quality time there. I will get it done little by little.
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Mon Jan 23, 2023 10:07 am
Thoroughly cleaning Lizzie and re-painting some wood. She cleans up pretty well.
Get a horse !
EricMac
First Name: Eric
Last Name: Macleod
Post by EricMac » Mon Jan 23, 2023 1:52 pm
I have been working on replacing the top on my '26 Touring. Other than windshield hardware and paint I'm about ready for the top itself.
Top bows 2
Top bows 2
Top bows 1
Top bows 1
1913 Touring
1926 Touring (2006 Stynoski)
1927 Fordor (2)
1927 Touring
EricMac
First Name: Eric
Last Name: Macleod
Post by EricMac » Sat Jan 28, 2023 1:08 pm
I just picked up another. This time a '24 Touring. Thanks to Mark Eyre for the help rounding this one up.
Rich's T
Rich's T
1913 Touring
1927 Fordor (2)
1927 Touring
Model T Ron
First Name: Ronald
Last Name: Bakow
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Post by Model T Ron » Sat Jan 28, 2023 11:14 pm
I did not do near as much as the guys above but I did get my car out for the first time this year....washed it, cleaned the grime i got on my new tires when installing them. Then I went for a nice ride and got some fresh gas. I also think I got the oldes car at the gas station award lol :lol: [image][/image]
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Post by BobShirleyAtlantaTx » Sun Jan 29, 2023 2:42 am
Those are some good looking casings! They sure set the automobile off.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Sun Jan 29, 2023 3:34 am
I am just finishing the rebuild of a 1917 engine.
Looking for a good low head.
Andre
Belgium
Arbs
Last Name: A
Post by Arbs » Mon Jan 30, 2023 5:55 pm
Andre
Belgium
Nice work Andre. Het ziet er perfect uit!
NY John T
Last Name: Killelea
Post by NY John T » Mon Jan 30, 2023 8:12 pm
I finally finished rebuilding the front end. The axle had been bent slightly from hitting something (tree? car? wall?) before I pulled it out of a barn. The perches were on backwards and so the right wheel had positive caster and the left wheel had slight negative caster. The wishbone had been broken and welded with a piece of angle iron. Needless to say, the car drove a little strange.
I took everything apart, cleaned, painted, and put slip plate on the springs. I had the spindle bushings redone and did anything that needed repair. It's now in the car as of yesterday and awaiting a test drive. Here's a photo of the front end before installing.
John
fbergski
First Name: Philip
Last Name: Berg
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1916 Coupelet
Post by fbergski » Mon Jan 30, 2023 8:24 pm
Haven't been on the forum much lately but I've made great strides in my fuel injection project on my 16 t. Now comes the test drive phase, still a few months away while I install it on the car.
Post by Norman Kling » Mon Jan 30, 2023 8:41 pm
Added one quart oil and oiled the fittings added some coolant to the radiator of my Screwed down the grease cups a bit, checked tire pressure, and drove the 22 Runabout to the local museum for open house. Saturday it was clear, that is when I took it. just a little chilly. Today it has been raining very hard.
modernbeat
First Name: Jason
Last Name: McDaniel
* REQUIRED* Type and Year of Model Ts owned: 1913 Roadster / 1926 Pickup / 1926 Express-Camper
Post by modernbeat » Tue Jan 31, 2023 8:18 am
Finished the custom engine build and installation. Finished the custom wiring. And have started to dial in the tune.
Jason McDaniel
Last Name: Strange
Post by CudaMan » Tue Jan 31, 2023 10:36 am
Wow, very nice! Some of those little Holley carbs came with clear glass float bowls.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Tue Jan 31, 2023 10:53 am
Moved my 1919 from the shop garage to the house garage so my son could put his modern iron in the shop for repairs.
It was cold, about 30*, but nice and sunny so Ruby and I took a quick spin around the neighborhood.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue Jan 31, 2023 1:41 pm
I am getting ready for what I plan to do next month. Like tomorrow.
Art Mirtes
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Tue Jan 31, 2023 4:58 pm
Getting it together, finally after 25 years
