Changing out fan bushings
Rich P. Bingham
First Name: Rich
Last Name: Bingham
Post by Rich P. Bingham » Mon Jan 02, 2023 1:54 pm
I have my own ideas on this, but I'll bet our members have some good tips ! 1916-20 (?) cast iron hub. Thanks, fellows !
Last edited by Rich P. Bingham on Mon Jan 02, 2023 4:01 pm, edited 1 time in total.
kevinf
First Name: Kevin
Last Name: Fielding
Re: Changing out fan bushings
Post by kevinf » Mon Jan 02, 2023 2:37 pm
Rich, we used to take out poilet bushings this way. If the hole is a blind hole, run a pipe thread tap in the bushing. I am guessing that would be about 3/8 NPT. Thread in a grease zerk and hook up your grease gun.
Hope that helps, just remember it's only one way to make naked cats.
Kevin
kevinf
First Name: Kevin
Last Name: Fielding
Post by kevinf » Mon Jan 02, 2023 2:50 pm
Oops just saw this was posted on the classifieds. Looks like Steve's the winner.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Jan 02, 2023 3:39 pm
If you screw a tap into the bushing, just use a long punch or a rod against the end of the tap and knock the bushing out from the opposite direction.
Same for spindle bushings.
