New clutch drum
greenacres36
First Name: Brian
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1915 Runabout
New clutch drum
Post by greenacres36 » Sun Jan 08, 2023 9:11 pm
I am in the process of making a couple new clutch drums. The only dimension I am missing is from the face the washers right against to the set screw hole. Obviously that is critical. I know there were two different numbers for early cars and late cars. At least that is what I understand. Does anybody have that dimension or a drawing?
Thank you in advance.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: New clutch drum
Post by Dan McEachern » Sun Jan 08, 2023 9:14 pm
Joe Bell
First Name: Joe
Last Name: Bell
Re: New clutch drum
Post by Joe Bell » Sun Jan 08, 2023 9:28 pm
Brian I have boxes of them, you are welcome to what you need, I am in Tiffin Ohio!
greenacres36
First Name: Brian
Last Name: Williams
Re: New clutch drum
Post by greenacres36 » Sun Jan 08, 2023 9:44 pm
I sent a pm to you Joe
