Stewart Model 100 speedometer adjustment.
Post by Steve Jelf » Wed Jan 11, 2023 11:34 pm
Rather than send the question directly to Russ, I'll post it here in case others are interested too. After working on the head and checking whether it works with a reverse drill, I reinstalled it in the car and tried it out today when I drove to town for groceries. It works, but reads low. With GPS showing 32 mph the speedometer shows about 20. Going 37 to 38 gets the speedometer up to 25. In a drive around the block, a known 2½ miles, the odometer ran up 2.45. If my figuring is right, that works out to a reading of 98 miles per actual 100. I call that close enough for gummint work. The odometer is the part that's important to me, because I want a running count of total miles. An electrical odometer resets to 0 if you have to change the battery, so this is better.
Though the odometer is more important to me, it would be nice to have the speedometer show closer to the actual speed. I'm guessing that the adjustment built into the Model 100 is not enough to correct the current under-reading, and that this head needs a change of spring. Is that right?
Re: Stewart Model 100 speedometer adjustment.
Post by TRDxB2 » Thu Jan 12, 2023 2:37 am
Here is a link to an explanation Russ provided in 2015 about calibration
https://www.mtfca.com/discus/messages/5 ... 1422581728
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Thu Jan 12, 2023 3:42 pm
Steve,
There are only three things that impact the speed on a Stewart speedometer:
1) the strength of the magnet
2) the strength of the return hair spring
3) the placement of the metal square tab found below the magnetic drum.
The metal square tab is probably what you need to move to increase he speed of your speedometer, but don't discount numbers one and two. Generally, moving the square tab to he left, or counterclockwise will increase the speed of the unit.
I hope this helps,
Russ Furstnow
Post by Steve Jelf » Thu Jan 12, 2023 3:48 pm
Thanks, Russ. I'll try the tab adjustment and see how much that does.
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Post by Bruce Compton » Tue Apr 22, 2025 5:50 pm
Can you actually replace the hair spring? I have two 1913 Stewarts, one with a perfect hair spring and terrible drum while the other has a messed up spring but nearly perfect drum.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Tue Apr 22, 2025 8:10 pm
The hair spring and the magnetic drum can both be replaced. The magnetic drum can be also re-magnetized. The big issue is being able to calibrate the speed once any changes have been made. I use a Stewart calibration machine, but these machines are somewhat rare. I hope this helps. Russ Furstnow
Bruce Compton
First Name: Bruce
Last Name: Compton
Post by Bruce Compton » Tue Apr 22, 2025 11:29 pm
Thanks Russ. What's the trick to replace the hair spring?? Bruce
dykker5502
First Name: Michael
Last Name: Deichmann
Post by dykker5502 » Wed Apr 23, 2025 8:31 am
Steve,
I hope this helps,
Russ Furstnow
But will that also fix the odometer issue? I doubt it and that was what Steve wrote was most important?
Ford Model T 1914 Touring
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Wed Apr 23, 2025 2:11 pm
The accuracy of the odometer is driven by the road and pinion gears. To determine the road/wheel gear that will make the odometer most accurate, determine the diameter of the tire and mulitply times two to get the number of teeth necessary for the road/wheel gear. The pinion gear will ALWAYS be 16 teeth. Steve's gearing must be pretty good to show 98 miles for an actual 100 miles traveled! I hope this helps. Russ Furstnow
dykker5502
First Name: Michael
Post by dykker5502 » Fri Apr 25, 2025 5:10 am
My point exactly, Russ :-) - so Steve will have to live with 2% error. Or experiment with various tires as some may just hit the nail spot on.
Post by Wayne Sheldon » Fri Apr 25, 2025 6:20 pm
Tire circumference varies by minor size variations due to brand, batch, and wear. A two percent error is about as close as it gets.
