U-Joint question
tselliott
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
U-Joint question
Post by tselliott » Mon Jan 16, 2023 1:15 am
Can anybody tell me what this u-joint is for?
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: U-Joint question
Post by mtntee20 » Mon Jan 16, 2023 9:50 am
It appears to be an adapter from the transmission output to an auxiliary transmission input. Doesn't appear to be for the old Warfords as they were/are square on both input and output.
Good Luck,
Terry
Post by Mark Gregush » Mon Jan 16, 2023 11:36 am
Scott, you might try post here: https://forums.aaca.org/forum/66-what-is-it/ or https://www.smokstak.com/forum/forums/a ... trucks.57/
I am thinking it is for different make of car or truck that used that configuration.
Post by DanTreace » Mon Jan 16, 2023 1:36 pm
Perhaps it’s for a Muncie, older post shows similar.
Moxie26
Last Name: Jablonski
Post by Moxie26 » Mon Jan 16, 2023 1:47 pm
Check the Ford Model A parts book.
Post by Rich Eagle » Mon Jan 16, 2023 1:57 pm
Chevrolet used 4 bolts and splines like that. Others probably did too.
Somewhat similar. 34-36 Chev.
https://www.vintageplanet.ca/OEM-GM-Uni ... _1371.html
33 chev truck
https://autopartsobsolete.com/1933-Chev ... 64440.html
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Jan 16, 2023 7:58 pm
I pickup some once they where marked Chevy and I have seen them in a Chevy trans adapted to a model T before.
I had hopped they could be used to make a Muncie coupling but the square is to large. I did use one of the cages to make a
model A to Model T joint If one was to use a model A trans for a Aux. trans.
Dennis_Brown
Last Name: Brown
Post by Dennis_Brown » Mon Jan 16, 2023 10:28 pm
Does it have a game fitting? Some older tractors had the splined pto shaft and a square drive shaft to an implement.
