block to tappet clearance
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Mon Jan 16, 2023 4:27 pm
Getting ready to order a reamer for oversize tappets. What is the recommended
clearance between the tappet and block ?
Thank you for any help .
Re: block to tappet clearance
Post by Scott_Conger » Mon Jan 16, 2023 4:31 pm
Buy a piloted reamer from the suppliers along with matching lifters. Use a mechanical guide to put the reamer in the CENTER of things and you'll be good to go without worrying about calculating clearances.
Take a look here for valve guide clearance and fixturing...not for lifters but good info for your review: http://www.mtfca.com/discus/messages/70 ... 1510948496
