Was lost but now it's found
5 WoodenWheels
First Name: Gerrit
Last Name: Marks
Post by 5 WoodenWheels » Mon Jan 16, 2023 5:56 pm
I posted some time ago about having to possibly pull the motor and hogshead to find the end of a magnetic tool that had come off while doing some exploration which in hindsight wasn't necessary to begin with. I won't get into that story. Not now, anyway. So a fellow club member came over on Sunday and immediately found the offending object and fished it out. I'd bought a borescope and because he knew what he was looking at--unlike me--he was able to recognize something that shouldn't be in there where it didn't belong. Happy day. If there's any lesson to be imparted here, it's that the cheap Harbor Freight flexible magnetic tool will unscrew itself if you give it half a chance and attach itself to the nearest metal object. I don't know what the cure is other than not to use that particular tool unless you have good access to any place it's probing. It was jammed between the flywheel and something else as far as I can tell--which caused the motor to be stuck. Looking forward to rebuilding the starter bendix and getting the car back together for the next adventure.
Re: Was lost but now it's found
Post by Scott_Conger » Mon Jan 16, 2023 7:20 pm
Excellent!
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Jan 16, 2023 7:35 pm
Hi Gerrit,
Try one of this style they are available from many other suppliers. A bore scope is worth its weight in gold.
5 WoodenWheels
First Name: Gerrit
Last Name: Marks
Post by 5 WoodenWheels » Mon Jan 16, 2023 7:50 pm
Hi Gerrit,
IMG_2434.jpg[/attachment[attachment=0]IMG_2434.jpg
Thanks. Yes, the borescope is a really nice tool and it didn't break the bank. I got the Depstech brand, not the cheapest model and not the most expensive. Somewhere in the middle but the price difference wasn't that great. Well under $100. They're also good for looking under the sofa, fridge, inside walls, etc.
I'll keep the magnetic pickup tool around for those times where I don't have to probe in hard-to-reach places. Might just glue the head on since I don't use the little light anyway..
Post by Jerry VanOoteghem » Mon Jan 16, 2023 8:26 pm
My doctor friend and I used a proctoscope. It had the advantage of a retractable wire loop at the end, which we used to "lasso" a wayward nut. We did this for a mutual friend, who nearly cried when we extracted the nut from his transmission.
I can see the possibility for a lot of jokes here. Feel free...
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Mon Jan 16, 2023 8:48 pm
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Mon Jan 16, 2023 10:15 pm
Jerry,is this what you are referring to?
https://www.ebay.com/itm/265943969664?h ... R-K4v9u3YQ
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Jan 17, 2023 12:44 am
I think that is the analog version not the digital.
Post by Jerry VanOoteghem » Tue Jan 17, 2023 6:34 am
That's correct.
Post by Jerry VanOoteghem » Tue Jan 17, 2023 6:35 am
Jerry I hope that the scope won’t be put back in regular patient services ha, however those scopes are invaluable. Being on a first name basis with my gastroenterologist, because of my yearly colonoscopy, with the optional 20 foot garden hose, schedule post surgery from a few years back. Luckily he was able to find his SEC championship ring from the last procedure or at least that’s what it felt like.
John,
It was actually never used on a human, thank goodness...
Last Name: Wrenn
Post by TWrenn » Tue Jan 17, 2023 9:14 am
John,
John...a YEARLY colonoscopy?!? Wow. Sorry pal. Every 5 years is bad 'nuff, but the prep is really the worst part.
Aside from that...try having the ol' scope shoved up the "periscope" to check your bladder buddy! Now THAT'S a real trip!! :lol: :oops:
Post by JTT3 » Tue Jan 17, 2023 3:23 pm
Tim this was my last year of annual scopes didn’t find anything but a very small polyp so now it will be every 3 years. As far as the other area of interest, been there and done that. That my friend was the most uncomfortable thing I’ve ever had done. I’m not saying that it was but I’m almost sure they used bobbed wire. At least it felt like it every few hours when the urge presented ha.
Post by speedytinc » Tue Jan 17, 2023 3:41 pm
You have to make sure your doctor removes his class ring. They call that a speed bump.
Post by Jerry VanOoteghem » Tue Jan 17, 2023 3:47 pm
John,
I think they just use the scope and keep their fingers out of the process. :lol:
(I think you're thinking of a digital prostate exam.)
Hey, lets' get back to Model T's, I'm getting a little queasy :mrgreen:
