Wanted 7 rivet crankcase pan and aluminum handle starting crank
robert daniello
Last Name: D
Post by robert daniello » Sat Jan 21, 2023 2:24 pm
I am looking for a 7 rivet crankcase for an otherwise fairly correct early '12. For some reason someone changed the block onto to a wide nose pan and the original was not saved, perhaps it was damaged. Anyway, please let me know if you have one that you are looking to sell.
Also, looking for an aluminum handle starting crank. Worn out etc. is fine, willing and able to rebuild it. Thanks.
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Re: Wanted 7 rivet crankcase pan and aluminum handle starting crank
Post by frontyboy » Sun Jan 22, 2023 10:48 pm
I have a 1914 narrow neck pan that has been straightened on a KRW jig, I just removed it from my '14 and replaced it with a 4 dip pan. Since I had the pan straightened, I drove the car about 60 miles and lost a rod, decided I wanted better access to the 4 rod bearing so I replaced the pan. I will count the rivets tomorrow and post the count here.
frontyboy
Last Name: Hatch
Post by Dan Hatch » Mon Jan 23, 2023 5:33 am
Hard to come by. I found the nicest one I have seen in years at Luray last year. You should come this year.
