TT Overloads?
BUSHMIKE
Topic author - Posts: 355
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
TT Overloads?
Has anyone seen these before? Unfortunately we cant see the rear pad or shackle. I have to wonder if its a legit aftermarket kit or homemade.
Re: TT Overloads?
That looks like a serious aftermarket quality mounting bracket, not homemade. The idea must turn your TT into a TTT.
BUSHMIKE
- First Name: Mike
Re: TT Overloads?
Or it could be a frame mount for a “normal” rear spring?
got10carz
- Last Name: Meixner
Re: TT Overloads?
I think they could be springs from a late teens Chevy mounted th the frame. Like a model 490 .
Re: TT Overloads?
Those would be ideal on a bus.
Re: TT Overloads?
I agree it looks factory made. If it had been used on more TT's perhaps fewer of them today would have broken upper spring leaves from overloading. I bet there are a lot more broken upper leaves than we know, because you don't see them unless you take the spring out of the frame.
- First Name: Adrian
- Last Name: Whiteman
Re: TT Overloads?
Now that would make a nice talking point on your TT.
Go for it! I would seriously try to outbid you if I was in the USA
