Rear axle bearings
Craig E. Luton
First Name: Craig
Last Name: Luton
* REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Rear axle bearings
Post by Craig E. Luton » Tue Jan 24, 2023 3:25 pm
Can anyone give me the dia. of the roller in the rear axle roller bearings when they were new?
Thank you in advance Craig
Last Name: Tannehill
Board Member Since: 2002
Re: Rear axle bearings
Post by JTT3 » Tue Jan 24, 2023 3:33 pm
.499 I believe
Post by speedytinc » Tue Jan 24, 2023 3:36 pm
.500" Measured from nos.
Post by JTT3 » Tue Jan 24, 2023 3:44 pm
John when you measure are you doing both ends & the middle? Just curious. I need a better caliper, ha.
Post by speedytinc » Tue Jan 24, 2023 3:50 pm
The new one measures .500 the whole length. The rollers were ground the same the whole length.
Used bearings - both ends & middle. They typically wear in a cigar shape if the cages were loose.
Post by Jerry VanOoteghem » Tue Jan 24, 2023 4:30 pm
I measure each end. I do not like tapered ones, (more than a few thousandths anyway).
I'd go with a micrometer instead of a caliper. More accurate.
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Post by BUSHMIKE » Tue Jan 24, 2023 5:01 pm
More than once I have had an apprentice come to me with an undersize part clamped between his calipers. I would ask to see the calipers, whereby I would send them flying into a dark back corner of the shop. I would then calmly ask him to bring me his 0-1” mic with calibration standard. I would take whatever time was needed to show him how to properly calibrate the mic…to the tenth, in most cases. They never forgot the lesson. A caliper has NO place in precision measurement. Fine for roughing work, sorting drill bits or selecting shim stock, but not in the toolroom.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Tue Jan 24, 2023 5:41 pm
The rollers were segmented in size classes. Each class was within .0002 inch. No need to measure these brgs to the nearest .0002 inch today. Just be glad there are still serviceable brgs. Eventually they will be used up.
Properly installed and maintained they should last for another century. But will they with current practices, I doubt it.
Art Mirtes
Post by JTT3 » Tue Jan 24, 2023 6:29 pm
Bush Mike send me those old calipers. I’ve got micrometers but it takes too long when it’s raining and you moving from one vendor to another ha.
2nighthawks
First Name: Harold
Last Name: Schwendeman
Post by 2nighthawks » Tue Jan 24, 2023 6:40 pm
Realizing that this is pretty much "common knowledge" but in case there is someone that is not aware of this, there are four identical rear axle bearings (two inner and two outer) and the outer rear axle bearings, because they support the entire weight of the rear of the car, tend to wear much more than the two inner bearings, which wear very little as they do not support any weight at all. Typically, a car with very worn outer bearings will have inner bearings that usually show no wear at all. It's those INNER bearings that we are looking for at swap meets and the only to find them is with an accurate micrometer! FWIW,....harold
BUSHMIKE
Last Name: Cushway
Post by BUSHMIKE » Tue Jan 24, 2023 7:02 pm
Harold,
Logical and interesting data. Thanx!
BUSHMIKE
Last Name: Cushway
Post by BUSHMIKE » Tue Jan 24, 2023 7:06 pm
John,
You need to attend the Spring Jefferson Swap Meet. Every couple of years is snowing. I always felt bad for the vendors wives that were there bundled up in garbage bags and tarps to keep dry. Some looked absolutely miserable.
