Button on the dash
Barteldes
First Name: Bill
Last Name: Barteldes
* REQUIRED* Type and Year of Model Ts owned: 1924 Coup
Button on the dash
Post by Barteldes » Mon Jan 30, 2023 11:41 am
24 Model T Coupe: There is a button to the left of the steering wheel on the dashboard. Any thoughts of what it does? I hope i can attach a picture.
BIll B
No matter how you shake and dance the last few drops go down your pants.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Button on the dash
Post by Humblej » Mon Jan 30, 2023 11:53 am
Looks like a light switch.
Post by TRDxB2 » Mon Jan 30, 2023 11:55 am
Its a push/pull light switch 1915 - 1917 . was mounted to the right of coil boxes on the dash(firewall). It might be used form some other function
Barteldes
First Name: Bill
Post by Barteldes » Mon Jan 30, 2023 12:57 pm
Thanks you guys ... im new at this but not afraid to ask questions. So much knowledge here in this chat!
BIll B
Post by Rich Eagle » Mon Jan 30, 2023 1:05 pm
It might have been for a spotlight. I have used switches on the dash to cut power to the generator when cutouts were faulty. It obviously was added at some time after production.
I'm glad for those not afraid to ask.
Post by Steve Jelf » Mon Jan 30, 2023 1:23 pm
Is it just the switch, or are there wires you can follow?
Post by John kuehn » Mon Jan 30, 2023 2:12 pm
See if you can see any screw holes on the side of the door posts. There may have a spotlight or something like it mounted years ago.
But put you hand under the dash and see if there are wires on the backside of the switch. Maybe you can wiggle or pull them a little and have someone look under the hood where the wiring block is. That’s probably where any wires would have been. That switch is located on the same side of the car as the wiring block is.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Jan 30, 2023 2:20 pm
Be careful until you trace the wires, an ex fighter pilot may have owned the car..
Post by Steve Jelf » Mon Jan 30, 2023 2:38 pm
I would expect a wire from the terminal block to the switch, and another from the switch to whatever accessory it's for. If the accessory is gone, that second wire might lead to its location and suggest what it was.
Barteldes
First Name: Bill
Post by Barteldes » Mon Jan 30, 2023 5:03 pm
God i love you guys!
BIll B
