The front camshaft bearing (notched style ) needs to be babbitted and bored.
Also the front camshaft journal and thrust face also needs to be touched up by
grinding.
Can anyone tell me what the original length was so that I can determine what
the new reworked length would be ?
Thank You
John
Front Camshaft Bearing Length
Re: Front Camshaft Bearing Length
I have a NOS bearing - I'll measure it up when I hit the shop.
johnr
Topic author - Posts: 62
- Last Name: Delamater
- * REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Thank you Steve
- Last Name: van Ekeren
By the book specs, the bearing length is, 1.967"
Here’s a run down of ModelT specifications. I looked up T specs for the cam bearing and ran into it. https://www.macsautoparts.com/modelt_specs
This is something that should be included in the resources section on the MTFCA website.
Yes I know it’s Macs but they did make a handy reference guide. The MTFCA could do their own.
If I remember some suppliers used to include T information in their catalogs but most have quit doing it.
I have several NOS - un-split, notched fronts - 1.966 - 1.967
If your cam has been reground, chances are there is no heel left, check it. If that is the case you will need to install a thrust kit.
https://www.modeltford.com/item/3042TK.aspx
What can happen is the lobe can drop into the notch without the thrust kit that is installed between the cover and timing gear.
