SOLD: K R Wilson Model T Pan Straightening Jig
GatorsModelT
First Name: Eric "Gator" & Paula
Last Name: Gould
* REQUIRED* Type and Year of Model Ts owned: 1915 Southern Wide Track Touring, 1918 Couplet, 1919 Canopy Express,1920 Center Door Sedan
Board Member Since: 2003
Post by GatorsModelT » Tue Feb 14, 2023 10:42 pm
SOLD: KR Wilson Model T Pan Straightening Jig. Very good shape, has not been used as an anvil. $1,000
Last Name: Tannehill
Board Member Since: 2002
Re: For Sale: K R Wilson Model T Pan Straightening Jig
Post by JTT3 » Tue Feb 14, 2023 11:20 pm
Gator I want it, I’ll give you a call in the morning on the pan Jig.
sweet23
First Name: Darryl
Last Name: Bobzin
Post by sweet23 » Wed Feb 15, 2023 8:03 am
John, You are about to gain many new friends with your purchase.
Re: SOLD: K R Wilson Model T Pan Straightening Jig
Post by JTT3 » Wed Feb 15, 2023 5:22 pm
Ha I’m afraid so. Best John
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Wed Feb 15, 2023 8:36 pm
Hey John, this is your new friend Dave. When are you moving to Ohio??
Post by JTT3 » Wed Feb 15, 2023 9:16 pm
LOL, well my 1st cousin lives there, he’s about to retire from the USAF & has decided to stay in the cold Midwest. I suppose I’ll need to find the front saddle before I can do anything ha
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Wed Feb 15, 2023 10:15 pm
John. Nice looking jig. You will need to find and install the "taper pins" in the tail shaft for the cone. The taper pins is what sets the alignment of the tail shaft. There should also be 2 taper pins in the front plate for the hand crank test pin. Without the taper pins there is no accuracy. McCaster Carr has the little pins for the top of the table. It takes 10 pins but buy 20. They are cheap and you will break them from time to time. If you buy the McCaster Carr pins you must aneal them by heating them up to a "dull red" and let cool slowly. As sold they are too hard. Of the ten pin holes 6 of them go all the way thru the table. A broken pin can be driven on thru the table no problem. The other 4 holes are blind holes. If you do not areal the pins it is very very very difficult to drill the broken pin for removal. Trust me on that one. If you need any info on where to get the few missing test pins, give me a call.
I have several new friends since I got my pan jig :)
Post by JTT3 » Wed Feb 15, 2023 10:58 pm
Donnie I’ll call you in the morning or you can call me. Got a bunch of questions, Matt will be happy to know we can get the pins. Best John
Randall strickland
First Name: Randall
Last Name: Strickland
Post by Randall strickland » Thu Feb 16, 2023 7:50 am
Mark I use a weed burner to heat block as it heats a larger area and retains the heat better.https://www.youtube.com/watch?v=https:/ ... d3Hdqq6GSI
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Thu Feb 16, 2023 8:37 am
Randal youtube says the video is no longer available.
