13 - 15 bulb horn
Craig E. Luton
Topic author - Posts: 196
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
13 - 15 bulb horn
I am told that there is a difference between the 1913, 1914 and 15 bulb horns. Can anyone explain to me just what that difference is? I do know that there is different mounting brackets used on the bulb horns of that era (the cast bracket that bolts the horn to the wood dash); some are oval and others are round in shape. What is correct for 1913 and/or 1914?
Thank you in advance
Craig
Craig
got10carz
- Last Name: Meixner
Re: 13 - 15 bulb horn
This is what I believe, 13 round, 14 oval, 15 oval sort of with scallops.
- Last Name: Tannehill
- Board Member Since: 2002
Steve is correct I believe.
Scott Rosenthal
- Last Name: Rosenthal
That round base was used on latter 12 also, if not mistaken.
Bob McDaniel
- First Name: Bob
- Last Name: McDaniel
There is some very good information at the end of this thread:
http://www.mtfca.com/discus/messages/59 ... 1483212466
Rich's referenced link is golden (brass) just some pics from it
