Testing a magneto horn
Reno Speedster
Topic author - Posts: 625
- First Name: Morgan
- Last Name: Blanchard
I have a decent magneto horn that will never use since my cars have generators. I would like to test it to confirm it works before offering it for sale. Any hints on the best way to do that using my car?
Re: Testing a magneto horn
One wire from the mag to the terminal on the horn. Ground wire from the horn body to the car body/engine/frame. Adjustment screw is in the center of the diaphragm.
Reno Speedster
Sounds good.
The adjustment screw is in the centre of the diaphragm, deep in the trumpet. I made a tool to do the adjustment , consisting of a socket wrench welded to a steel tube, and a T handled screwdriver with long shaft to drop down the tube.
