More Schrader Valve Stems on Ebay
Last Name: Strange
Post by CudaMan » Fri Feb 24, 2023 7:48 am
I have no connection to the listings or the seller, just providing the links as a courtesy:
https://www.ebay.com/itm/144959518431?h ... R_KQnrfQYQ
https://www.ebay.com/itm/144959484398?h ... R_KQnrfQYQ
Re: More Schrader Valve Stems on Ebay
Post by Original Smith » Fri Feb 24, 2023 12:12 pm
I'm glad I started collecting them when I did. People are starting to find out the repros aren't the same as the originals. They can't even make a bridge washer correctly!
Last Name: Strange
Post by CudaMan » Sat Mar 04, 2023 9:07 am
Both the auction and "buy it now" valve stem listings ended without any purchases or bids, they have since been re-listed.
The Schrader 888 stems are nearly identical to the 777s, the only difference is that they are 1/4 inch shorter.
The Dill stems are functionally identical to Schrader, only the logo stampings are different.
Again, I have no connection to the listings or the seller, just providing this info as a courtesy. :)
