Spindle Bushings - to paint or not to paint
namdc3
First Name: Nikolaus
Last Name: Martin
Post by namdc3 » Sat Jan 12, 2019 6:00 pm
Should the visible outside edge of the spindle bushings be left natural, or were they painted black after assembly? In other words, when all is said and done, should you see brass-colored rings or should you see all black?
JWalters
First Name: Jason
Last Name: Walters
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Re: Spindle Bushings - to paint or not to paint
Post by JWalters » Sun Jan 13, 2019 2:27 am
Probably painted black after assembly at the factory. I like the unpainted look myself tho.
Charles Weisgerber
First Name: Charles
Last Name: Weisgerber
* REQUIRED* Type and Year of Model Ts owned: 1925 Tudor.
Post by Charles Weisgerber » Sun Jan 13, 2019 2:45 am
Let the Bronze show. That way it’s easy to see at a glance if the bushings have adaquet oil. Just my opinion.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sun Jan 13, 2019 5:19 pm
According to the mtfca encyclopedia, under the heading of paint, the front axle was first assembled then was painted, therefore, the bushings would be painted, as would nuts and cotterpins.
namdc3
Last Name: Martin
Post by namdc3 » Sat Jan 19, 2019 7:46 pm
Thanks for the replies!
