Speedo parts for sale
Larry LaPatka
Last Name: LaPatka
* REQUIRED* Type and Year of Model Ts owned: 13 Pie Wagon, 13 Depot Hack,14 Bell Telephone Service Truck, 14 Delivery "C" Cab, 30 Model A Closed Cab
Post by Larry LaPatka » Sat Feb 25, 2023 11:30 pm
Excess for my needs speedo gear and plate.
Both for $75.00 plus postage.
Thank You
Re: Speedo parts for sale
Post by Mark Gregush » Sun Feb 26, 2023 12:35 am
The top one is for AC setup and bottom one looks to be for Stewart. Because we cannot click on the images for bigger view, maybe more information would be in order esp on the No 2.
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Post by Russ_Furstnow » Sun Feb 26, 2023 9:30 am
The second gear is a reproduction Stewart gear. It appears to be a cast gear, not a machined steel one as there are no holes drilled in the gear for mounting. I hope this helps, Russ Furstnow
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Feb 26, 2023 4:28 pm
Also, the first top gear, which is an AC is for wooden wheels only. A different gear, made exactly the same except a fourth tab and mounting hole were added, was used with wire wheels.
electfearless
First Name: Freddie
Last Name: Carver
Post by electfearless » Wed Apr 12, 2023 9:56 pm
The second gear is a reproduction Stewart gear. It appears to be a cast gear, not a machined steel one as there are no holes drilled in the gear for mounting. I hope this helps, Russ Furstnow funny shooter 2
Is it still available for sale?
1924 Model TT Truck
1930 Model A Pheaton
