After working on your Model T What parts do you have left over?
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Wed Mar 01, 2023 10:15 am
There has been a discussion on engine splash pans.
Some, begrudgingly, replace remove and replace the pans.
Others remove the pans completely and either discard, hang on wall, or sell. Left over parts.
Some will rebuild a starter or generator, motor, transmission and find that every thing is back together except a screw, gasket, or spring is found...it was removed but not placed back in position. Parts left over.
Any of you have parts left over?
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Re: After working on your Model T What parts do you have left over?
Post by MichaelPawelek » Wed Mar 01, 2023 10:19 am
After rebuilding three Model T’s I have enough spare parts to build all the mechanical running gear for number four!
Post by Steve Jelf » Wed Mar 01, 2023 10:53 am
My problem when reassembling isn't parts left over. It's trying to remember where I put the parts I need to reinstall. Where is my 1915 dash shield?
Post by Mark Gregush » Wed Mar 01, 2023 11:19 am
Generally, I don't have left over parts. :lol: Most of the time they are parts that jumped into the parts washer feeling lonely wanting to be with the rest of the group so when I get done, just think they are leftovers. ;)
Petrah Phyre
First Name: Sean
Last Name: Pownall
* REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Post by Petrah Phyre » Wed Mar 01, 2023 11:47 am
When I inherited my '26 speedster I was told I had to take the rest of the leftover parts. Except tires and wheels, I should be able to assemble two additional chassis.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Wed Mar 01, 2023 11:54 am
Water pump, distributor, 12v battery, disc brakes, flower vase,
Post by Norman Kling » Wed Mar 01, 2023 12:04 pm
Only the parts you replaced should be left over. Do the work in a few days or you might be like me. I order new parts when I am putting things back together and then after I am all done, I find the new parts I had ordered when I took it apart a year ago! The worst thing to have happen is to find something that needed to go in first, such as the wire around the heads of the flywheel to crankshaft bolts and you have a 3 dip pan and everything else is together. Not the best case because you likely would not know until the flywheel and transmission get loose. Other things could be the inside oil line. So be sure to check everything step by step while you are assembling to be sure nothing necessary is left out.
Post by TRDxB2 » Wed Mar 01, 2023 1:53 pm
Lots of spare parts.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Wed Mar 01, 2023 3:21 pm
Having owned over 45 model Ts And worked on many moresince tge early 90s
I have had to keep spare down to a minimum
Basically just keep consumibles
Gaskets hoses ect
Bryant
First Name: Bryant
Last Name: Shafer
Post by Bryant » Wed Mar 01, 2023 6:55 pm
:lol:
