Double Venturi needed for 1928 zenith or holley
Jwinters
First Name: Joseph
Last Name: Winters
* REQUIRED* Type and Year of Model Ts owned: 1923 pickup
Post by Jwinters » Fri Mar 03, 2023 9:54 am
Rebuilding a carburetor and this is the missing part
Thanks for looking
Re: Double Venturi needed for 1928 zenith or holley
Post by Mark Gregush » Fri Mar 03, 2023 12:58 pm
This information was just posted on Fordbarn. You may be able to use a single venturi.
https://www.fordbarn.com/forum/showthre ... le+Venturi
I only did a quick read, did not see if Snyders still had any, they did in the past.
Post by TRDxB2 » Fri Mar 03, 2023 2:35 pm
Checked lots of Model A sites Mikes $32 but doesn't indicate availability https://www.mikes-afordable.com/product/A9586A.html
Snyder's , Exckelr's, SNJ out of stock
