WTB - Hayes Rear Spoke Rims (demountable) need 2
gwk
First Name: Gary
Last Name: Kindy
Post by gwk » Wed Mar 08, 2023 10:06 am
I am looking for 2 Hayes Rear Spoke Rims, with small brake drums, that are demountable to buy.
The rim should accommodate a 30 x 3 1/2 inch tire.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: WTB - Hayes Rear Spoke Rims (demountable) need 2
Post by Kevin Pharis » Wed Mar 08, 2023 10:26 am
Rims with small brake drums…? Is it safe to assume that you are looking for Hayes demountable wire wheels? Best to specify also if you are looking for 23” clincher or 21” rim diameter.
If you find some, take a close look at the keyways in the hubs as they are known to wallow out
gwk
First Name: Gary
Last Name: Kindy
Post by gwk » Wed Mar 08, 2023 10:53 am
Thank you Kevin for your help.
I’m sending you a private message.
Post by Allan » Wed Mar 08, 2023 7:10 pm
The flogged out keyways Kevin mentioned are common on Hayes wire spoked wheels. I have a way to correct this I can share, but it does involve removing the hub from the wheel. Finding hubs is a bonus. Having good brake drums is another bonus, so it may well be worthwhile to strip and re-spoke a wheel.
