o Fully rebuilt Ruckstell large drum rear axle assembly including a Ruckstell center shifter & control rod, relined emergency brake shoes with rods & and supports – painted gloss black – full assembly ready to install.
o The total rebuild included all NEW: standard ring & pinion, axle shafts, hardened bearing sleeves, inner and outer modern seals, bushings, shims, thrust washer, drive shaft & bushing, modern pinion bearing, shift lock assembly, emergency brake cams & bushings, emergency brake shoes with hand brake rods & and supports.
o Full disassembly, cleaned, inspected, repaired as needed, then professionally reassembled with high quality parts. Then a quality high gloss black paint was applied. This is a full high quality Ruckstell rear axle assembly!
o Complete build sheet of parts & cost upon request. Must pick up. Can be delivered to Chickasha. $3850 - Changed price due to typo. Email me at markpaulagember AT aol dot com[
SOLD
SOLD- FS Ruckstell Large Drum Rebuilt Rear Axle Assembly
MAG
Topic author - Posts: 494
- Last Name: Gember
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring 1926 Runabout 1926 Coupe 1929 Tudor
- Attachments
- LD Ruckstell 2s.jpg (61.65 KiB) Viewed 1264 times
- LD Ruckstell 3s.jpg (62.94 KiB) Viewed 1264 times
- LD Ruckstell 4s.jpg (47.69 KiB) Viewed 1264 times
- LD Ruckstell 5s.jpg (60.67 KiB) Viewed 1264 times
- LD Ruckstell 6s.jpg (48.87 KiB) Viewed 1264 times
MAG
- Last Name: Gember
Re: FS Ruckstell Large Drum Rebuilt Rear Axle Assembly CHANGED PRICE
Updated price to $3850 due to typo in original add.
