Ignition timing coil & spark tester
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Mar 15, 2023 8:57 pm
US Pat. 1184154 May 23 1916 Automatic Motor Control Corp NY city TDC dial indicator with spark cap gauge. Five plug adapters, 5 piston
probes with locks & wires ( had to machine the one for model T adaptor) Thanks to Dan Hatch I know what this is, Weidenhoff I think is
the Mfg. This is a very period correct tool for collecting or using. Dial gives very accurate travel in 100s of an inch. $225 + shipping will
fit in USPS end load flat Rate box.
IMG_2492 (1).jpg (46.62 KiB) Viewed 741 times
IMG_2493 (1).jpg (15.98 KiB) Viewed 741 times
IMG_2494 (1).jpg (16.98 KiB) Viewed 741 times
Please email or call 6027six 9 zero two 57
First Name: craig
Last Name: leach
Re: Ignition timing coil & spark tester
Post by Craig Leach » Thu Mar 16, 2023 1:46 pm
Sale pending. Thanks Richard.
