Mystery Tool identification
Steve King
Last Name: King
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 25 Coupe, , 26 Touring, 22 Aluminum Fordor, 23 Coupe
Board Member Since: 2010
Post by Steve King » Thu Mar 16, 2023 9:34 pm
I bought 2 large trailers of T parts and this tool shown in front of the drum stack was in the mix. Does anyone know what it does? is it T related? B.S.V.CO embossed on the bottom.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Mystery Tool identification
Post by Jack Putnam, in Ohio » Thu Mar 16, 2023 9:43 pm
Maybe tenon cutter?
Steve King
Last Name: King
Post by Steve King » Thu Mar 16, 2023 10:03 pm
Looks like a file could slide in the rectangular slot and the disk would index to select a hole size
Steve King
Last Name: King
Post by Steve King » Thu Mar 16, 2023 10:05 pm
A look from the bottom.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Thu Mar 16, 2023 10:22 pm
Jack is right it’s a dowel tenon cutter.
http://thevalleywoodworker.blogspot.com ... -such.html
Last Name: Strange
Post by CudaMan » Fri Mar 17, 2023 8:48 am
You can see one in action here (about 13 minutes in):
https://www.youtube.com/watch?v=VCi8l0B-zlo
Steve King
Last Name: King
Post by Steve King » Fri Mar 17, 2023 10:02 am
Thank you guys. Thanks for the video link! Looks like I would need to find the cutter that mounts in it to make it complete although I'm not sure I'm ready to take on building a wheel. Wheel wrights are a craftsman on a different level and probably need excellent patience. My background having retired as a steamfitter and paper machine mechanic doesn't always lend itself well to this hobby.
Dennis_Brown
Last Name: Brown
Post by Dennis_Brown » Fri Mar 17, 2023 10:06 pm
Would the square tapered end fit in a hand brace? My dad had an antique drill press that took that type of tapered head. You could run it from a flat belt or hand crank it.
Post by Mark Gregush » Sat Mar 18, 2023 12:27 pm
Besides the missing blade, one would also need the cone cutter to get things centered and started.
https://www.woodworkersjournal.com/cham ... er-dowels/
