Padding on a belly band?
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Sat Mar 18, 2023 2:41 am
I have a spare belly band and I would like to put it on the 22. Would it be a good idea to put some sort of pad between the band and the pan? I was thinking oil soaked leather or the like. Anyone done this?
Last Name: House
Re: Padding on a belly band?
Post by George House » Sat Mar 18, 2023 7:20 am
Yes !! I cut out a 4”x4” from a truck mud flap and cut a hole for the oil drain. Once I used an old leather glove.
RGould1910
Last Name: Gould
Post by RGould1910 » Sat Mar 18, 2023 10:01 am
Yes, I cut a leather pad to fit between the pan and brace to keep the brace from rubbing.
Post by TRDxB2 » Sat Mar 18, 2023 11:53 am
I would think that a pad would only prevent some wear from metal to metal contact and not act as a cushion.
I'm planning on coating mine with Flex Seal Paste. I used this before and it dried to a hard rubber surface. The only concern is how tight a bond it will make with the metal. But its worth a try and same concern with other methods. I didn't use all of the contents of the jar in my last project and it dried hard after a few weeks when it was sealed tight. Thinking the tube might last longer since just the tip is exposed to the air.
flex seal.png (131.54 KiB) Viewed 992 times
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sat Mar 18, 2023 12:44 pm
I cut some sheet rubber to match the belly pan shape, no adhesive, and installed a few years ago only to be lubricated by leaky oil level valves from the side of the pan
