Wanderng speedometer swivel?
Post by Steve Jelf » Mon Mar 20, 2023 12:28 pm
The swivel for the Stewart 100 speedometer on my 1915 runabout is attached to the spindle arm by a clamp. Even with the nuts tightened to "almost before it breaks", the clamp wants to wander and disengage the gears. So I'm wondering about installing a 2696B spindle arm, That's the one with a hole for mounting a swivel. But I wonder about the fit. Would it cause the 1919 & later under-axle wishbone to interfere with the steering connecting rod? Would there be any fitment problems I haven't thought of?
Re: Wanderng speedometer swivel?
Post by TXGOAT2 » Mon Mar 20, 2023 12:44 pm
I've had some good results tightening things like that by putting coarse grit, like coarse valve grinding compound, between the surfaces and then clamping. Coarse emery cloth might do as well.
