townsend aluminum connecting rods
Gene_French
Topic author - Posts: 1075
- First Name: Gene
- Last Name: French
- Board Member Since: 2014
for sale : set of Townsend auto. cast aluminum connecting rods ... these are designed for use in fitting Model A crankshaft into Model T motor block ... the machining instructions are included ... machining will require lathe and milling machine work ... price is $150 + $17.10 flat rate postage in lower 48 states ... actual postage outside this area or INTERNATIONAL ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Gene_French
- First Name: Gene
- Last Name: French
Re: townsend aluminum connecting rods
I am uncertain regarding the question of running aluminum rod directly on the steel crankshaft rod throw ... many small engines and air compressors do exactly that ... i have re-babbitted aluminum connecting rods for Lycoming ( Auburn ) engines , so the rods can be babbitted ... regarding the wristpin end ... this is bored to wristpin diameter and slotted in the same manner as the original T rods ... hope this answers some of the questions on this rod set ... the machining process will be time consuming and will require careful work , this is NOT an "add water and stir " operation ...always an optimist ...Gene French
Gene_French
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
Gene_French
- First Name: Gene
- Last Name: French
