Here is the 2nd steering column to be identified. (Last one).
Column Length is about 54-56 inches.
Steering wheel is finger-jointed wood.
Spark and Throttle control levers are near the top of the column and have spring loaded lockers to maintain a setting.
The control levers and quadrants might be brass, but I have not done a test.
*** Thank you in advance for identifying the 2nd steering column. MT5.
Identify 2nd Steering Column if you can.
W Austen
- First Name: Bill
- Last Name: Austen
- * REQUIRED* Type and Year of Model Ts owned: 1915
Re: Identify 2nd Steering Column if you can.
1910 Mitchell
MT5Tony
Topic author - Posts: 12
- First Name: Tony
- Last Name: Cerovski
- * REQUIRED* Type and Year of Model Ts owned: Six 1926-7 Roadsters, One 1925 cutoff, & One-27-Coupe
Hi Bill,
Thank you for the helpful information.
I've posted pictures from a restored 1910 Mitchell, as the steering columns mate up very well.
Now I need to find someone who can use it. Thank you, MT%.
- Last Name: House
Place the ad on HCCA Classifieds. They charge $$ for pictures tho.
- Last Name: House
