On my ‘26 Touring the top bows ,that fit into the irons , have a “tenon” cut on them …
Does anyone have the length ,between tenons on all four bows ..I’m most concerned about the #1 & #4 bows …
The ones on them right now ,,look original ….But are different than the ones in the kit I got with the car …
They are from the Gentleman that produced them in Northern Calif……
Thanks in advance …Carl…
‘26 Touring Top Bows
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: ‘26 Touring Top Bows
Determine the length of the #1 bow by using the windshield stantion clamps to set the correct length. You can use the #1 bow length for all the other bow lengths. When the top is folded all the bows should line up on the saddle.
Mustang1964s
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Are the Top Bows different on the '26 than on the '27?
The length between the first and second are different. It seems that the last is a little shorter than the third.
