NOS AIR
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
NOS AIR
Post by ThreePedalTapDancer » Sat Apr 01, 2023 1:57 pm
I have a limited quantity of 1920s era correct air for sale. I had an old tube that I removed from a petrified tire, and it was still full of air. The tire was stored since the late 20s. The tube unfortunately started to leak once removed, so I decided to run around and capture the vintage air in some small mason jars. It is a must for that correct restoration, and also to silence the annoying purists at the next show. Air removal from the jar the responsibility of buyer. 20.00 per jar plus shipping.
Bruce Compton
First Name: Bruce
Last Name: Compton
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
Re: NOS AIR
Post by Bruce Compton » Sat Apr 01, 2023 2:23 pm
Great idea ED. I am thinking of marketing genuine Canadian spring water for Model Ts as apparently "spring water never freezes", so you can use it all winter and save buying anti-freeze. Shipping might be an issue though........
havnfun
First Name: Joe
Last Name: Kowalczyk
Re: NOS AIR
Post by havnfun » Sat Apr 01, 2023 2:32 pm
Ed, that’s fantastic, bring over two jars as I have two low tires on my 23 touring.
Regards,
Re: NOS AIR
Post by Scott_Conger » Sat Apr 01, 2023 2:52 pm
How much is shipping?
Last Name: Strange
Re: NOS AIR
Post by CudaMan » Sat Apr 01, 2023 3:35 pm
LOL!
A long time ago, I saw an interview with someone who had visited White Sands, NM and brought some of the sand home with them in a jar.
They said that the ranger told them that the sands were expanding and they said they had proof because they had to dump some of the sand out of the jar every few years, otherwise it would break from the expanding sand. :)
Re: NOS AIR
Post by TRDxB2 » Sat Apr 01, 2023 3:43 pm
I believe that is a modern jar full of NORS air
This is the period correct NOS 8-)
24TFORDOR
First Name: Jeremy
Last Name: Donavich
* REQUIRED* Type and Year of Model Ts owned: 1924 T Fordor
Board Member Since: 2023
Re: NOS AIR
Post by 24TFORDOR » Sat Apr 01, 2023 4:25 pm
ROTFL. Brilliant business idea!
First Name: Dallas
Last Name: Landers
Re: NOS AIR
Post by Dallas Landers » Sat Apr 01, 2023 4:31 pm
My tire is only 2 lbs low. How much per lb ? I dont think I need a full jar.
Adam
First Name: Adam
Last Name: Doleshal
Re: NOS AIR
Post by Adam » Sat Apr 01, 2023 4:59 pm
Hi Ed, I’ll take ten jars. I’m mailing you a check for over the amount. Please forward the balance to my shipper…
Re: NOS AIR
Post by TXGOAT2 » Sat Apr 01, 2023 5:53 pm
Anyone remember "Pink Air"?
Dennis Prince
Last Name: Prince
Re: NOS AIR
Post by Dennis Prince » Sat Apr 01, 2023 11:53 pm
I run OE dirt on my car , it is hard to get but worth the effort.
Re: NOS AIR
Post by Allan » Sun Apr 02, 2023 7:58 am
You guys need to be very careful of this opportunity. You should be aware that under the beliefs of homoeopaths, all the air on Earth contai s traces of that air that was present in the 1920's. You are wasting money just to get a more concentrated version.
Re: NOS AIR
Post by Jerry VanOoteghem » Sun Apr 02, 2023 8:41 am
Do you have any plans to offer NOS 1920's water? My T only cools well with original water.
jaybee47
First Name: jay
Last Name: bolante
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Re: NOS AIR
Post by jaybee47 » Sun Apr 02, 2023 10:25 am
I have 17 gallons of used non-detergent oil for sale. Very thick and very black. 2 cents per gallon. Shipped in 1 gallon Ziplock bags only. Can be safely delivered by steam boat.
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Re: NOS AIR
Post by FundyTides » Sun Apr 02, 2023 11:24 am
How about some NOS smoke, captured as it escaped from original Model T wire harness just before the electrical system failed. Obvious that if the smoke was reinstalled carefully, the electric system would work again. A similar product has been marketed by Lucas suppliers for use in the dreaded "Prince of Darkness" systems used in vintage British cars. That product probably wouldn't work in Model T's as it is for 12 v systems.
Re: NOS AIR
Post by Rich Eagle » Sun Apr 02, 2023 12:03 pm
"20.00 per jar?" That's inflation for you. :lol:
First Name: Dallas
Last Name: Landers
Re: NOS AIR
Post by Dallas Landers » Sun Apr 02, 2023 12:09 pm
I only have one of each. For the serious restoration only. Taking bids now.
Sean Butler
First Name: Sean
Last Name: Butler
Re: NOS AIR
Post by Sean Butler » Sun Apr 02, 2023 12:35 pm
Back in 1980 after Mt. St. Helens blew, you could buy small vials of ash in the tourist shops. Or... you could scoop it up by the shovel full in the parking lot of the same shop :o
Sean Butler
Huntington Beach, CA
Last Name: Tannehill
Board Member Since: 2002
Re: NOS AIR
Post by JTT3 » Sun Apr 02, 2023 1:41 pm
Ed do you know if the air is from a tire with the red tube or the black tube? I have original white smoothies and I don’t want them to turn yellowish. As you can see on the profile picture I bought some original air from another vendor and it started to yellow my tires. I ordered some tire paint to paint them white again, which was expensive, the maker was Barn or Barns white paint based on the label.
Bowerusa@msn.com
First Name: Ray
Last Name: Bower
* REQUIRED* Type and Year of Model Ts owned: 1926 TT
Re: NOS AIR
Post by Bowerusa@msn.com » Sun Apr 02, 2023 2:03 pm
If you have period-correct scotch, I am a buyer.
First Name: craig
Last Name: leach
Re: NOS AIR
Post by Craig Leach » Mon Apr 03, 2023 4:10 am
I told a friend about your add. ( he's into antique British motorcycles ) He wants to know if you have any period correct British air? He already
has Lucus & Miller smoke. ( Lucas prince of darkness & Miller king of darkness ) I heard once that Lucas had the contract for the electronics
for the space shuttle. Do you supose if there was a question about the electrics they had to do a space walk & wave their hand in front of the
headlight to check? I asked a British gentaleman one day if it was true that the British drank warm beer because they had Lucas refrigerators
He asked how that taxation with representation was working out for us.
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Re: NOS AIR
Post by t-time » Mon Apr 03, 2023 9:12 am
Ever seen the Lucas vacuum cleaner? ................It's the only thing they made that didn't suck!
FundyTides
First Name: David
Last Name: Wilson
Re: NOS AIR
Post by FundyTides » Mon Apr 03, 2023 9:43 am
Lucas user manual instruction "Be home before dark"
First Name: craig
Last Name: leach
Re: NOS AIR
Post by Craig Leach » Mon Apr 03, 2023 10:45 am
Lucas gets a bad rap but they invented the four posision switch ON, OFF, INTERMITENT & DEAD SHORT which gave us the intermitent windshield
wiper.
SoNorCal
First Name: Jim
Last Name: Lukash
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring
Board Member Since: 2009
Re: NOS AIR
Post by SoNorCal » Mon Apr 03, 2023 5:34 pm
I had a jar of NOS air at my space in Bakersfield and Tulare, never even got a question much less an offer.
(I am not smart enough to post a photo, or I would)
So the present value of NOS air is $0.00, based on market research
