Model A Glass Sediment Bowl on '26 T?
Professor Fate
Last Name: S
Post by Professor Fate » Tue Apr 04, 2023 8:19 pm
Anyone ever try a model A style glass sediment bowl on a '26-'27? Just curious.....
________________
**FATE**
Re: Model A Glass Sediment Bowl on '26 T?
Post by Mark Gregush » Tue Apr 04, 2023 8:22 pm
Where the fuel line is fitted is straight thread not tapered pipe thread at the inlet end and 1/2 20 Ford thread at the other.
Post by TXGOAT2 » Tue Apr 04, 2023 8:51 pm
My '27 has a tractor-type screened glass bowl located where the original style sediment bulb is supposed to be. It works very well.
Professor Fate
Last Name: S
Post by Professor Fate » Wed Apr 05, 2023 4:44 am
Thank you!
________________
**FATE**
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Thu Apr 06, 2023 4:44 am
I use a glass sediment bowl. Not a Model A type, but for a John Deere tractor (part no. AM3100T). It's been there for 20 years and never given any trouble.
Post by Steve Jelf » Thu Apr 06, 2023 10:46 am
An old time glass bowl filter is not likely to give you any trouble, but isn't it just a repetition of the sediment bulb? I don't think it adds any extra protection.
Post by TXGOAT2 » Thu Apr 06, 2023 11:29 am
Same function, assuming the screen is the same size mesh. But you can see debris. Obvious non- originality.
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Apr 06, 2023 1:01 pm
You can get the glass bowl filters with both side & top inlets. I have a top inlet on my firetruck. Most have a shutoff valve on them & can be
purchased @ NAPA, Tractor Supply and suppliers like Steiner Tractor.
